sutor623
- May 23, 2011
- 4,089
Reality check, your boat is 20 yrs. old. Over the next 5 yrs. you'll see more and more degradation.
I suspect your boat has more water intrusion problems that you know or care to admit (denial). If you'll look back at the pics you took when you first got your boat you'll see quite a bit of black mildew in it, that's not a good sign.
You can't truthfully say that your deck and stringers are solid and your foam is dry until you lift the decking and check everything out. There may not be much rot in there right now, but I'd be money there is plenty of wet stuff under your deck that is the same ticking time bomb that you have on your transom. All of this stuff is typical for a 20 yr. old fiberglass boat that hasn't been kept garaged or covered when not in use.
IMO, Seacast isn't worth the money unless you plan to keep the boat for a very long time.
If you don't like doing fiberglass work, you should own a brand new fiberglass boat or an aluminum boat. Older fiberglass boats are nothing but a bunch of work and money until you tear them apart and put them back together with new and dry material.
Actually, I can see/inspect the stringers in many spots due to all of the compartments of this boat. They are solid. There are numerous spots where you can see directly under the deck also. The manufacturer did do a great job at glassing in the deck. Foam is also dry. I cut out part of the stringer to get my other pedestal base mounted the proper way and it is very dry under there. Foam looks great. You can also see the foam in the rear of the boat when you take the side compartments out. And actually, this boat was kept under a covered carport for most of its life. The past 5 years it just was setting under a covered carport and I saw it each time I visited my old buddy. The water that got in more than likely came from the lake that this boat went crusin' on.
I guess I will think a little harder about this. At this point Im not too worried about the structure so I may just wait until the off-season. The only issue with that is it SUCKS not being able to do glass work etc. because of the cold.
