Outboard Engine & Electrical Cutting Off - Not Restarting
cgav34
Just sold my boat, and the new owner took it out for the first time today. He called me at the ramp advising the motor cut off, after he got it off the trailer, and it wouldn't restart. By the time I got there, he advised the motor had started after they pressed one of the trim tab up/down buttons. He cut if off, and I checked the fuel bulb, thinking that maybe the engine wasn't getting enough fuel. The bulb seemed very soft, so I pumped it a few times. He cut the motor on, and took off down the river.
He called a couple hours later advising the motor had cut off a few more times, and that when it does, they also lose all electrical power. He advised there was a little black wire that wasn't connected to anything, in the battery compartment. When he touched it to the positive terminal of the main battery, it would spark a little, and everything seemed to reset...to where he could start the motor again.
Any ideas what could be causing this? It's a 2015 Nautic Star 214 XTS center console with a single battery, on a switch, that operates the electronics and starter. I'm pretty sure that little black wire has never been connected to anything, but I could be wrong. I've never disconnected any of the wires from the battery, and I've never experienced this problem in the three years I owned the boat.
levittownnick
I would Not connect the Black wire to the Positive terminal. Try to find what that wire is connected to.
cgav34
New owner said he tried to trace the rouge wire, but was unable to find out where it went to.
One thing I noticed yesterday, when I was trying to help him, was that the protective cover for the + battery terminal was off, and laying in floor floor of the compartment (he said they put a charger on the battery, just in case, before their first trip, and maybe didn't install the cover back). Only thing I can think is that the black wire moved and touched the terminal, causing a short that killed everything. Can't figure out why touching the wire to the terminal again would cause the power to come back on, and allow for cranking again though.
