Outboard engine change on 1968 clipper
m_sherman211
I have a 1968 CLIPPER Runabout 16'.
I has a POS chrysler55 outboard on it. Im looking to change it out but Iam wondering if anybody knows if it the boat will take a 100hp Johnson. Im told the Johnson weighs 275lb. Not sure if this boat can handle it.
Anybody have idea.:confused:
Frank Acampora
Re: Outboard engine change on 1968 clipper
Well, look at the capacity plate for max horsepower. Your Chrysler 55 weighs around 156-160 so the Johnson will be over 100 pounds heavier.
If your hull is rated for 100 horsepower and you feel uncomfortable, put a couple of cement blocks on the transom to see how low she will sit at rest with the Johnson
100 HP on a 16' boat can be overpowered, depending on the type of hull and what she is rated for. Normally a Bass Boat would be rated for that power, but a light runabout would be rated for 85HP or maybe less. Can you post a picture of the hull?
Frank Acampora
And by the way: You 55 is most likely not a POS, you just don't understand it. I have three of them and they are simple to work on and easy to maintain. Before you decide to swap: Go over to the Force/Chrysler forum and describe your problem(s) we can help and unless completely trashed, the engine will give you many hours of pleasure
m_sherman211
This si the only pic I can find at the moment,Screenshot_2014-01-17-11-08-15.jpg
m_sherman211
Un fortunately this motor gave someone else many hours of pleasure!:D
Sorry, I cannot see that picture clearer. Looks like a runabout, vice a bassboat. Likely 100HP will overpower it, which might be fun for a while, until the transom starts to crack off.
m_sherman211
I will check the tag but Im pretty sure it doesn't have a max hp rating on it. Just weight capacity.
JimS123
Back in the day I had one very similar to it. Standard power was a 40 with a 60 as an option. The 40 was a perfect size for that hull.
My friend had a 16 Winner, of about that age. Looks a lot like that boat. We had an 85HP Merc on it, but whenever you hit a wave the hull in the bow would noticably flex. Pretty scary, but it never cracked. I would stick with a max of 75HP.
m_sherman211
Yeah I think 75hp might be the best.
