Outboard bogs down under load
SolomonCraig
My 25 hp Tohatsu 4-stroke has just recently been having a lot of problems when put in gear. Out of the water in gear it revs high and runs fine, which is the same with it in neutral in/out of water. Everything seems perfect until about 1/3 of the throttle where the power quits increasing. I've taken apart and cleaned the carb as well as replaced spark plugs and fuel filter. I know there has been similar posts about this problem but I've seemed to read them all and can't get anywhere. The boat ran fine the first couple times out this season then out of nowhere in the middle of lake it dropped rpm's and has been giving us problems since. Really appreciate any help I can get.
SolomonCraig
Re: Outboard bogs down under load
..After doing some more research I have found a couple threads that talk about Float Adjustment. How extensive would this be?
junior1113
your in the right website but wrong forum go to outboard repair forum and repost in your brand. good luck
