Fordracing17
Thread starter- Joined
- Mar 12, 2016
- 26
1994 mercury xri 200. This thing is a nightmare the problem is bogging out of hole. I step on hotfoot and rpms rise to about 3000 and cut out then won't run but 2000 rpm. Then the next day runs like a scalded ape. It is intermittly but as time goes on it is getting more frequent. The following is a list of parts and some things I have done.
Low pressure fuel pump
High pressure pump
6 plugs
6 wires
6 coils
2 switch boxes
Trigger
Stator
All fuel line boat and motor
Replaced all filters
Cleaned vst
Made resistor circuit bypassing various sensors to rule out sensor problem
Checked tps in spec
Has 40 psi of fuel pressure
Thanks
High pressure pump
6 plugs
6 wires
6 coils
2 switch boxes
Trigger
Stator
Cleaned vst
Checked tps in spec
Thanks
