JonBoat55
Thread starter- Joined
- Aug 26, 2019
- 97
1999 Regal 1800, Mer 3.0, Apha1Gen2
Just finished doing end of season maintenance. New impeller kit and all gaskets, shift assembly and gaskets for the lower. Pulled the upper to inspect everything (u joints, alignment all looked good) and replaced with new gaskets and o rings. Put everything back together and ran it to check for leaks after new oil and filter was done.
Is the water exiting the out drive looking correct? This might just be a sanity check, I don't remember the water flowing out below the exhaust bellows like that. And I really don't remember water spraying out of the area right above the shift dog ( see video) and weep hole on the lower.
What did I install backwards?
