This is a 14' fiberglass V hull fishing boat. I have a 7.5hp outboard on it. I believe it is a Sears model but its old, probably from the '50's.
It was taking on a little water. Not a lot, but I could be out on the lake for 3-4 hours and there was maybe 2 inches accumulated back at the transom is all. Put it this way, nothing that a little bilge pump couldn't take care of.
So I decided to take up the floor and have a look see. I found some main stringer rot in a 3 foot section, see the pictures. This rot coincides with where someone attempted to use bondo on the bottom of the boat to fix a soft spot. With those visual clues, I am almost certain this is the source of my water taking-on.
The rot is such that I can poke it with a flat screwdriver and it goes in about an inch. Plus the fiberglass has pretty much eroded off of it.
So here is the questions and where I need the advice and opinions.
1. Should I do a complete stringer replacement?
2. Can I just piece in a 3ft section of stringer where the rot is and re-glass?
3. Can I just re-glass over what is there and hope it works? (I almost didnt ask this!)
4. Should I just leave it and get a bilge pump.
This isnt a junk boat, but it isnt a "cherry" either. So anything I do to it doesnt have to be pretty. Functional and Economical being the key words here.
If there is a stringer replacement project in my future, any advice is appreciated!
Some additional photos: http://s298.photobucket.com/albums/mm270/markh28/Boat Stringer/
