Opinion on mid- 80 50 hp merc
COZMOS
Hi. My 50 hp evinrude just blew up on me and this guy has a mid 80`s 50 hp 3 cly merc. I`m new to boating so what are your thoughts on this motor.I just bought the boat .So im kind of leary right now. So any input would be great thanks.
latin monkey
Re: Opinion on mid- 80 50 hp merc
bring a compression gauge and check the compression on all cylinders, see if the motor runs and better yet if its on a boat take it on the water and run it. how much does he want for it?
COZMOS
1600.oo install . I had a short shaft so he has to raise the transom. Is merc a good brand as opposed to evinrude
latin monkey
well it mainly depends on how the motor was maintained over the years. has that motor been rebuilt? that price is high for an older motor
COZMOS
I don`t know much about the motor.I have to talk to him tomorrow.I`ll ask more about it
Fuzzytbay
Its better IMHO than that evinrude 50 you had, however, I would make sure you test out the compression on the motor before you buy it. If you don't know how, then bring someone who does. The last thing you need are two boat anchors. Also give it a good look over, ie, does the skag look like it and a hard object have meet in the past. HOw does it look under the cowling. Greasy oily, paint off the bolts, lie someone has taken it apart, that sort of stuff. Pull the drain plug on the bottom end, and look at the oil. IS it black, brown, white? Does the screw have metal shavings on the magnet portion of it?
Faztbullet
Pretty good motor ..just dont lugg it or overheat it. Make em install a new impeller also
