Re: Ooo! Sparkly! Redfury's Grinding again!
Well, didn't get much done the last couple of days, but....
Today was the fishing opener in MN. Of course, I had to work...I always work. But, as predictable as the sun rising and setting every day, The Fishing Opener was the same as it always is....Cold. Which was just fine with me, because that means I get to grind "sweat free". I got home from work and got on it!
Boy, I thought I got all the junk out of the boat years ago!
But, ALL the stringers are completely out of the boat now. There is NO wood that would be found under the floor ANYWHERE now. I thought they did a bad job glassing the stringers at the rear, but it was the worst at the bow..just dirty glass fibers
There it is, the stringers are GONE. Now, I get to clean the inside of the boat. But first, I think I need to pull the side panels off so I can get at the sides of the boat so I can remove the glass tabbing for the floor, so I can scuff it properly and attach the floor the right way...I'll probably end up rebuilding the side panels the way it's shaping up. Honestly, not that big of a deal at this point. I'm not going with the gold interior anyway.
The nose is all cleaned up. With this kind of progress, I can actually start thinking about cutting new stringer material for the boat....yay!
