What direction should the tips of the impeller blades be pointed ? I am not sure if they should be bent back to drag water around or bent forward to push water. Using the water discharge tube holding impeller housing at 12 o clock looking at the bottom as a reference. I understand the drive shaft rotates clockwise and that sometimes they will flip on their own but just want to start with them in the correct way.....Thanks
