One More question on old Evinrude
3 Bears
What direction should the tips of the impeller blades be pointed ? I am not sure if they should be bent back to drag water around or bent forward to push water. Using the water discharge tube holding impeller housing at 12 o clock looking at the bottom as a reference. I understand the drive shaft rotates clockwise and that sometimes they will flip on their own but just want to start with them in the correct way.....Thanks
jbuote
I am admittedly very new to outboards, but if the drive shaft rotates clockwise, then the impellor blades should bend counter-clockwise. (Bend back)..
​As for sometimes flip on their own??
The only reason I could see that happening is if the driveshaft rotated counter-clockwise, and if it did, I'd think it's a bigger issue.
​(added with edit) Every tip/article/video I've read or seen, says you install the impellor on the driveshaft, then rotate the driveshaft clockwise while pressing down on the housing to cover the impellor. That seats the impellor properly.
(end edit)
​Again, I'm new to outboards, but that's how I understand it to work..
​For what it's worth...
Honorary Supreme Mariner
Very simple the vanes bend backwards.----Look at it.---The pumping at slow speeds is done by changing volume between blades.---At high speeds it becomes a centrifugal pump.
Chinewalker
Best practice to rotate driveshaft clockwise when installing, as mentioned above. However, in reality, the impeller will self-right first time you start it up.
oldboat1
^^as stated. Not a concern -- sure not worth pulling apart to check. Make sure the key is in place, tube in the grommet, check water flow at powerhead -- can check pump operation with a drill, if curious. Before reattaching l.u., cover the unit in a tub of water and turn the driveshaft clockwise. Stream will show at the water tube grommet.
flyingscott
They do not always flip back I have taken plenty apart with vanes bent the wrong way. Definitely worth checking and making sure they are right.
Chinewalker
Chances are if the vanes are backwards, it's because the motor was turned backwards or the driveshaft was turned backwards on disassembly. Especially if you're finding "plenty" with that issue.
flyingscott
Nope the vanes will not always straighten them selves out. Plenty of posts about vanes being backwards and not flipping back.
mrmotts
Yeah, I've pulled impellers with only one or two vanes in the wrong direction.
I coat the inside of the water pump housing with dish detergent and a touch of water... makes for a real easy install while turning the driveshaft and pressing the housing down onto the impeller.
JDusza
Ouch! Don't let the petals seat themselves..Turn shaft clockwise as looking down from above. Petals should lag, not lead. DO NOT let the petals self align. Coat petals and inside of pump with silicon oil (spray) that'll help parts slide without rotting the rubber petals. mrmotts is correct, a soap solution will also work.
J
Also, before I do final assembly, I run the drive shaft with an electric drill and ensure water makes it all the way up the tube.
