One brake locks up!
motownbob
I have a shorelander trailer,had one wheel cylinder replaced last year, the other the year before. the trailer is a dual axle with one set of brakes. When i go to get the trailer to put the boat on, one of the trailer brakes is locked up, and i have to crack a fitting to release it. This Brake NEVER locks up with the boat on the trailer...What would be causing this? Bob
JB
Re: One brake locks up!
Rust in the drum.
Leaky grease seal may have contaminated the brake lining.
1 More Idea,.......<br /><br />When you Park the Trailer,...... Make Sure the Last Motion is in a forward direction,......<br />That way the Brakes are Released,+ in a Relaxed position,......<br />That way,.. They Shouldn't Hang Up.......
jlshields
If one of the wheel cylinders leaked brake fluid on a shoe, that will cause a shoe to stick to the drum.
Dunaruna
If you have to crack the fitting to release it, the system must be pressurized.<br /><br />Crude build up - change the fluid and give the system a good bleed through.
