Onboard charger
sebabmw
Hi there need some help , currently have a 2 bank charger which I am upgrading to a 3 bank to have ability to charge the main, I don't want to run the leads all the way back to the main, I assume I can run that lead to the fuse block? If so where on the block do I run these too? I know that prior to going to a 24v setup the shop setup the old charger that way, any info would be appreciated.
bruceb58
Honorary Supreme Mariner
If you have a battery switch, you won't be able to do that.
bruceb58
You can wire it up to the feed point to the fuse panel. If you aren't sure where to wire it, post a picture of your fuse panel and we can show you where to attach it.
I would always suggest having a battery turn off switch. That way, you can quickly disconnect your battery in an emergency or turn it off when you aren't using your boat to prevent the battery from discharging.
sebabmw
Thanks very much for your help it is the bluesea st blade with negative bus, I assume I will be connecting to the top and bottom studs ?
