OMC/Volvo Penta 4.3 Baseline Maintenance Checklist
Krandal
Hello All,
I am the recent new owner of a 1996 Four Winns H190, ran it last summer with only minor maintenance, changed fresh water impeller, thermostat and fuel pump. This is the year to bring it up to date. Last year began to see a slight oil sheen behind the boat on the last day out checked outdrive and it doesn't appear to be leaking externally when out of the water. I am thinking possible U-joint bellow? I have done much reading through manuals and this website but need some specific assistance over hoses and lower drive unit. Any other advice is appreciated. I apologize for the lengthy first post, I spent most of my life in engineering before I decided that I wanted to follow my childhood dream and become a fireman. :)
Volvo 4.3GL
MOD: 432BPNCS
SN: T01295122
Outdrive:
Volvo SX Cobra (from the identification chart in adults only it appears to be SX-S)
MOD: 386B413
SN: T00809027
Ratio: 1.66
To Do List Engine
Plugs - Champion RS12YC
Wires - VP 3888325
Cap - VP 3854331
Rotor - VP 3854311
Fuel filter - VP 0502906
Oil filter - VP 0502903
Belts x 3
- Dia. 44 - Alternator - VP 3852504
- Dia. 24 - Water pump - VP 3852336
- Main drive - ???????
Hoses x 7 (I don't count 7 hoses on the engine?)
- Dia. 37 - pump to thermostat - VP 3852288
- Dia. 58 - pump to reservior - VP 3855679
- Dia. 34 - gimbal to pump - VP 3855681
- Dia. 34 - cooler to pump - VP 3855678
- Dia. 34 - cooler to pump - VP 3852282
- Dia. 43 - thermostat to manifold - VP 3852746 x 2
To Do List Drive This is where I am concerned I might be missing a seal or something
U-joints - Spicer 5-1306X
Gimel bearing - VP 3853807
Exhaust bellows - VP 3850426
U-joint bellows - VP 3854127
Lower drive seal kit - VP 3855275
Bellows sealeant - ??????
Specific tools:
Various pullers - rental parts house
Engine alignment tool - 912273 or equivelant
Prop shaft tool - universal
Thanks again
Erik
Don S
Re: OMC/Volvo Penta 4.3 Baseline Maintenance Checklist
MOD: 432BPNCS, SN: T01295122
Those are OMC numbers. OMC and Volvo were in a joint venture in 94 through 98. Each sold under their own names, but the engines and drives were "Basically" the same. Not exact, but almost.
So I have moved this over to the OMC section.
Might want to check your part numbers with the BRP site to verify.
http://epc.brp.com/Index.aspx?lang=E&s1=a5b65c60-3576-4df7-b581-87217e4f0a1d&brands=ej
I would also suggest you stick with the OEM AC MR43LTS spark plugs and forget the champions.
Krandal
Thank you Don for the spark plug recommendation, ordered the AC's yesterday. So far I had some luck in cross referencing in the BRP catalog and was able to sort out my hose part number problem.
I still need assistance finding the main drive belt part number and the seals necessary to replace to properly seal lower unit after gimball replacement.
Thanks,
Erik
