OMC V4 prop to fit a 3 cyl?
steelespike
Re: OMC V4 prop to fit a 3 cyl?
the 15" rim fits inside the gearcasing, about 1/4 inch or so it's a bit narrow at the rear of the prop. But your right with the 19" it just butts up aaginst the gearcase.
Are you sure the 15" prop actually measures 13 3/4" in diameter?
It just seems so big in relation to the small gear case props The largest 15" prop is 12 1/4" in diameter.
jimmbo
Is this said to be for a small gear case?
It is for the V4 gearcase, you call it large, to me it is small. some of the other props listed are 13 3/8, 13 1/2, etc up to and including 14" dia. The small gearcase as you call it, can only handle small hub props up to 13' dia.
BTW I got that from the BRP website parts list.
fishfeatures
ok so I measured both hubs, at the rear where they fit into the gearcase.
15" = 12 inches
19" = 12 1/2 inches
the half inch difference is the issue why it wont fit in . Can I get the prop machined to remove 1/2 circumference , say get a lathe to do it or something??
jimmbo
15" = 12 inches
19" = 12 1/2 inches
I think you measured prop diameter. Or are you measuring circumference of the hub?
Maybe a few pictures of the prop and the motor could go along way
fishfeatures
you can see the two different sizes , it's obviously the smaller one that fits into the gearcase, so if I could machine it down 1/2 an inch all round would that work???
jimmbo
View attachment 158703View attachment 158704
Without any reference to compare against, it is impossible to judge the size of what is in the picture. Pics of the whole prop, with it on the engine. hubs butted against each other, against a ruler/tape measure.
fishfeatures
well it's dark and raining now so I'll post all that up for you tomorrow Jimmbo. cheers
steelespike
I probably got careless with the term "large gear case" The 60 was thought to have the large gear case which I figured
was the size of the v4 gear case.It noe appears the 60 may have a small gear case.
jimmbo
According to the BRP parts list. All the props listed for the 60 will fit the V4 case.
I guess there is a chance somebody swapped cases. but until our friend starts sending evidence to the contrary, I will say it has the V4 gearcase.
steelespike
15" = 12 inches
19" = 12 1/2 inches
Did you measure circumference? Or diameter?Did you measure from the center of the bore to the tip of one blade and double it"
steelespike
If I remember right there is a 60 listed as small gear case 78 on.Highest pitch 17" at iboats.
also the 1990 60 hp large gear case props are the same number as the v4 motors.
jimmbo
There was no 60hp in 1978, unless some oddball comercial unit, A 2 cylinder 60hp was introduced in 1980 that would have used the extra small gearcase. The 1990 brochure makes no reference to a small gearcsae and neither does Bombardiers website in the parts listing
steelespike
iboats prop list 60 2 stroke,thru hub 13 spline "small gear case" 78 and newer.
Of course no indication 2 or 3 cylinder Also mentions 2 cylinder 80-85.you mentioned.
So I guess that leaves us with a "V4 prop" that isn't what it is claimed.
fishfeatures
right guys , I have a spare gearbox so i put both props on it. with one prop measuring 12" and fitting in and the other measuring 12 1/2 and only butting up , I think I have to throw in the towel cause I don't think I have enough metal to machine down the larger one.
this is the 1/2 inch that won't ffit in
it should fill this space in the gearcase
but it only butts uup against it
I could try and use a lathe to take the 1/2 out of this but I don't think I have enough metal left
this is the spare with that 1/2 inch slotted in the case
steelespike
I think it is time to bite the bullet with a good new prop.
I think it will knock 300 to 400 off the rpm probably add a touch of speed.
Without looking back I forget exactly what we were looking for.
jimmbo
Are you smearing grease on the camera lens? Let's try something simple. You have a ruler. How about measuring the Diameter, that's diameter of the hub.
