alignment issue!!!!! NEED RESULTS TODAY
fishingman220
I have a 96 5.7 mercruiser with an alpha one gen 2, i am just putting the motor back in. now we had the motor out a few months ago and went back in no issues and the alignment was right. well going back in today, we got it down and tightened the rear mounts and then set it on the front and checked it and it was way off. i lifted the front of the motor and to make it right you had to lift the front to where the top of the motor mount on the motor were flush with the top of the studs on the stringer. i know something is not right with it and it got late and i stopped messing with it. just trying to find ideas on what to check or look at tomorrow morning. and ideas?????
Don S
Re: alignment issue
Re: alignment issue
Did you by any chance replace the rear mounts while it was out this last time? If you did, did you use new OEM mounts?
fishingman220
Re: alignment issue
Re: alignment issue
no, as far as the mounts and the bellhousing or coupler cover or rear motor mount( what is that cover called??) it is new , but was put on the last time it was out and put back in and the alignment was done after that was installed. i am thinking it is maybe hanging up or maybe the double lock washer might be sitting on something it shouldnt, i didnt know if this might be a common mistake or something
Wakesilver
Re: alignment issue
Re: alignment issue
On mine, the new rear mounts were taller and did not require any of the metal washers. If the extra washer was put in, the alignment tool would not even start to go into the coupler.
fishingman220
Re: alignment issue
Re: alignment issue
well i dont think it any wrong parts, because it has gone together before and nothing has changed since then, i will pick it back up and try again.
fishingman220
Re: alignment issue
Re: alignment issue
ok i have picked up the motor and tried putting back in and the same results. i dont know what else to check, any ideas??? i rented a chain fall for the weekend that has to go back tomorrow so it needs to be done today, any ideas would be great
fishingman220
Re: alignment issue!!!!! NEED RESULTS TODAY
i am going to pull the motor compleatly out and just put it back in, maybe i am missing something or it is sitting on something, it the only thing i can think of
fishingman220
pulled the motor and checked everything, everything seems to be fine, put back in and the same results
jtybt
The only thing I can think of is the gimbal bearing got out of alignment and you're trying to align the engine to a badly positioned gimbal. Don't take much.
fishingman220
what do you mean by knurled bottom??
fishingman220
i have a mac and it says it cannot open a window file. let me go get the numbers off the bellhousing, maybe i thought i had it lined up before and i didnt. i will get the number and check because they do stick a wase out of the bottom of the mounts.
fishingman220
4211025t_ and i cannot read the last number. the top says it for 4.3 alpha. the guy at the parts counter at mercruiser. said it was the same and it looked the same, can you tell if it is the newer one or older???
Bt Doctur
Look at the bottom of the bushing, if it`s smooth then it`s old style, if it has ridges, it`s new style.
fishingman220
so if it is new, do i take the double wound washer out and leave the fiber? i am preatty sure it has ridges
fishingman220
i did notice in the picture, mine sticks out of the botom alot more than the pitcure shows with the older
fishingman220
dropped off at a shop, said should be between 50-100 dollars depending on how stubborn it wants to be and will be eady by lunch tomorrow. i guess we will find out what the heck happened
Wakesilver
Hopefully it's not too bad at the shop. If you have the new style bushing with the flat washer or double lock washer you might be too high in the rear. It still does not explain it being good the one time bad the next...
