water n oil
- Sep 20, 2007
- 18
Hello again Mates,
I have a question about OMC tilt/trum unit #173827 Vs. #773530. I have a 1981 16 ft. Glastron SSV-151 with a 70 hp Johnson and want to add power tilt/trim to it. I was looking at OMC add on power tilt/trim kit #773530 that looked like it would fit my application then ran across add on power tilt/trim kit #173827.
Are these both the same kits that the part numbers have changed? Is one a three wire and one a two wire? What is the difference between the three wire and the two wire (besides the one extra wire)? Is one better than the other? I understand that these add on kits come with everything including the guage and the up/down switch that requires you to drill a hole and mount it. Any way to wire it thru a factory tilt/trim switch in the handle? Mine doesn't have one so would I have to replace the whole control box or can I change just the handle? Sorry for all the questions and thank you in advance for any help.
