misery
Thread starter- Joined
- Jul 18, 2010
- 98
So i know the tach thing has been beat to death on this site but i'm gonna ask this question anyway.
I finally have my 90hp ruddy working like a trooper, but my tach isn't hooked up. Its an omc tach with four wires. the light works and the needle will flinch when I feed it power so i think the unit is good. My problem is the plug in on my control box. i have the amphenol plug in but at some point in time the wires were cut off flush at its base. the male side of the plug in has the letters abc on the back. Which wires go where? I know that the grey wire is the Tach signal and the others are pretty easy. But in what order from left to right should i run this plug in. the female side of the plug in is built in to the control box and from the looks of the screws it won't be coming apart anytime soon so i can't see the wires inside the box.
Also I've read alot about the settings on the back of the tach, but mine has no such dial on the back of it. it has a rubber plug covering a small circular piece of metal with numbers around its circumference,but it is fixed and is not adjustable. does this mean that the tach is mated to this motor and needs no setting changes? I can't say for certain that this is the original motor to this boat or that the tach is the tach for this motor.
