j_k_bisson
- Oct 6, 2010
- 1,082
Before I start my rebuild/resto project I have been reading the OMC service manual for the motor and they reference a bunch of sealants, lubercants, and adhesives. Seeing that I know OMC does not make these themselves, I am wondering if they are known by other trade names like "loctite 242" and so forth. Here is the list.
OMC Premium Blend gearcase lube
OMC Triple-Guard Grease
Evinrude Outboard Lubricant
Evinrude XP Outboard Lubricant
General Electric Versilube
OMC Power Trim/Tilt and Power Steering Fuild
OMC Cleaning Solvent
OMC Pipe Sealant with Teflon
OMC Locquic Primer
OMC Gel Seal II
OMC Adhesive M
OMC Screw Lock
OMC Nut Lock
OMC Moly Lube
OMC Black Neoprene Dip
OMC Gel Seal and Gasket Remover
OMC Ultra Lock
OMC Needle Bearing Assembly Grease
OMC HT 400
OMC Gasket Sealing COmpound
Now I have a bunch of Merc Greases and Loctie products. Just hoping to not have to buy every one of these at $10 each. Any help would be appreciated.
OMC Locquic Primer
OMC Gel Seal II
OMC Adhesive M
OMC Screw Lock
OMC Nut Lock
OMC Moly Lube
OMC Ultra Lock
OMC HT 400
