OMC sea drive tilt/trim
rk21
i just picked up a 1983 omc 115 1.6lt outboard......it seem the person prior to me didnt have it hooked up right.there isnt any tilt or trim buttons on the shift lever and the round switch on the dash isnt hooked up either.....the wire from the shift lever goes to motor and there is a relay box on the ill say the back side of the motor...there is a five hole plug that isnt plugged into any thing...and then there is a black and white with red it appears to be cut then also the 2 wires that go to the the the plug thta goes to the trim motor from the relay box.....first time dealing with tilt/trim and im really lost......i saw one motor that was the same and it didnt even have that relay box there at all......any help would greatly appreciated.thank Skip
clanton
Re: OMC sea drive tilt/trim
The 2 wires from the relays to the T&T motor should be a blue wire for up, and a green wire for down. 3 wires from relays to switch on console or control handle. RED= hot, BLUE=up, GREEN=down.
rk21
Thank you so much....i will give that a shot in between the rain drops tomorrow......
r.j.dawg
Ensign
rk21 - post a pic if you can. I haven't seen one of those rigs in years. When I lived in Trenton Ontario a guy had a Boston Whaler style boat with twins. Man did that thing ever move.
rk21
well it appears the lift motor doesnt work....i tried hooking up the battery to the relays..they click but nothing work so i unplugged the green and blue wire plug and put the battery there still no movement.... i looked for a new motor and they are all obsolete,looked on ebay there are hundreds of them....but none seem to be the one that replaces the part number from omc....also can't seem to find any cross reference number either.........but i will get some pics today and put a few on.....
clanton
Look at ARCO web site in Pensacola Florida. Lots of wiring diagrams for T&T.
The Arco pn for your motor is 6220. OMC pn is 983446
rk21
Hmm i was looking on the ********** web site for my motor and it shows the part number to be 0173593 hydraulic pump and valve assy...... 1983 POWER TILT-TRIM OMC Outboard Accessories POWER TILT KIT ASSEMBLY 70-140 Diagram and Parts...i guess i got it all wrong......is that arco.com to find that motor......?...
clanton
Your thread title says sea drive. The motor in the photo is an outboard. The OMC number for this T&T motor is 0393988, Arco number is 6220.
clanton
You can find this motor on this site for $153.00, but you need to verify the T&T system you have. It could be a 2 wire or a 3 wire motor.
rk21
the model number for the motor is 2bbxctr...states its a 1983 115hp 1.6L omc sea drive outboard sorry if there was any confusion...there are 2 wires going to the motor from the relays....a blue and a green one that plugs into the plug from the trim motor...i thank you for your help....i will look into this.....
rk21
found a 2 wirs arco 6220 on ebay for 52.70$ free shipping.....thank you so much for your input....but hey im going to see if it starts in the am sometime...
r.j.dawg
Ensign
You beat me to it clanton. I was going to say that's not a Sea Drive. This is a Sea Drive.
rk21
so from this picture here someone must have mounted my motor on a different mount.....it just keep getting better...thanks guys for all your help......
rk21
WEll it runs really good.....fired right up..not sure how long it sat......any hints on how to get the 3 screws loose on the trim motor..lol......i sprayed some bp blaster on them...also how would you suggest looking for parts....seeing the model number and that states its a sea drive but it isnt....motor wise look at these parts and motor mount look for?.....thanks in advance..SKip
clanton
Parts from a 1983 V4 outboard should work. Water pump is same, ignition system is same, carb kits same.
Parts manuals on line, most of the numbers same as outboard.
rk21
Thank you Clanton for all you help......Skip....
clanton
You welcome, and I probley have the orignal OEM parts list, some where in my library
