OMC Outdrive tilt(or not)
grinner
I have an 1982 OMC with big rubber boot.
Tilt goes up only so far and than stops.It goes down without problem.
I was able after awhile to assist tilting it up by pressing the tilt button and at the same time lifting it with a rope.
Does anybody have any idea what the problem might be.
Thank you.
maxxman04
Re: OMC Outdrive tilt(or not)
tilt/trim limiter switch malfunction
WizeOne
No limit switch for the stringer outdrive.
What do you see, hear, feel when the drive ceases to go up?
You could have a tilt motor whose brushes are shot. The manual outlines a torque test for them.
I would also inspect your tilt gearbox and make sure it has oil, not water in it.
Other than those, I would check and clean all connections and grounds. I would also spray your two big 50A fuses connectors with electrical contact spray then rub a little dielectric grease over the female sides and reconnect them.
NW Redneck
Things to check are:
Battery fully charged?
Pivot bearings greased?
Tilt clutch gearbox full of water instead of oil?
Tilt clutch plates corroded?
Cover for tilt gearbox overtightened or missing gasket/shim?
Electrical connections to/from solenoids clean and tight?
Knife connections to tilt motor clean and tight?
Check all these things and let us know what you find. BTW, welcome to iboats! :D
NW Redneck
Good point. Mine only has one and works OK, but I have read from several sources that doubling them helps prevent binding the clutch.
enrecia
HELP can some1 tell me where to get a wireing dagram for a 1976 arrowglass cheetah or post a link to one plz i really need it:eek:
WizeOne
Methinks you should start a new thread, enrecia, instead of hanging your question on the end of someone elses post. And when you do, PLEASE include what kind of power system your boat has. A 1976 ArrowGlass Cheetah does not get us there!
