OMC control unit for 1996 Johnson outboard
Lakeside 1
Is there a diagram schematic somewhere that shows the positioning , adjustment of the throttle lever on the control box itself. Also.keys, I purchased two new keys that are numbered the same as the control box. they only go in as far as where the toothed part stops leaving half the key out of the ignition switch. Is that the way its supposed to be. Forgive me, I am new at this. This is a new used motor control box that goes with the motor I just purchased. the other motor was on this boat for 39 years ago The key fit in that control box fine
