I have a 1987 omc cobra 2.3 L manual shift on a 17' open sunbird.
The problem i am having is that it will not come out of forward when the engine is running goes in and out of reverse fine but once in forward it sticks there (will not come out ) when the engine is off it works fine forward reverse and nutral also when out of the water and hooked to the hose it works fine when running all gears . as soon as i put it in the water i have this problem . here is what i have done, both shift cables new , had entire lower unit apart , checked all adjustments and fluids , clutch dog is perfect along with everything in outdrive fluid has no water , also tore apart shifter controle and greased everything inside . and as i said everything works perfect out of the water but when i put it in the water it is like flipping a switch. PLEASE HELP I am at my wits end with this thing
