Lou C
- Nov 10, 2002
- 14,164
Agreed, when you said you could not get the trunnion set because you ran out of threads, I knew something had to be wrong with the cable, and I can't see any way you could get it set up right that way. The one on my boat is an OE cable but it has to be OLD....because it was on it when I bought it 17 years ago! I have always stored it with the drive down which helps the cables last longer. The last time I adjusted the cable was 6 years ago and the drag on the cable then was less than 2 lbs. Learning the adjustment process took me about a half day, and I used the instructions on the midnight wolf site even though I have a factory OMC 1988 shop manual because at the time, OMC did not have the special tools to adjust the cable, that came later, and that is what makes the adjustments more accurate and faster too. The procedure in the shop manual is more labor intensive and you are more likely to make mistakes than with the tools and the updated instructions.
