FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Re: OMC Cobra, How do I check oil on upper / lower?
On the dipstick on the top of the drive. The oil passages are connected so there is no checking the lower seperately, if the upper is ok, the lower if full.
Slotted screw on top of drive is a dipstick to check the level. If you want to drain the oil to check for water intrusion, remove dipstick, then remove slotted screw on the bottom of the drive near the skeg. I think you refill thru the middle slotted screw hole in the drive. Good luck on your purchase.
