nutnboltguy
Thread starter- Joined
- Jun 6, 2017
- 31
HT32BSX115 Hi Rick, I realize this post (OMC Cobra 4.3L Exhaust Manifold Overheating) was 6 years old, but would like to work off some of the past info if possible... Are the manifolds in the above schematic the "bat wing" style?
I have these on a recently acquired 88 Reinell 173E with the 4.3l OMC Cobra... and I like the way they look and would hate to get rid of them...
I purchased the boat with the disclosed knowledge of an overheating problem and a seized motor... completely rebuilt the motor with a new block because the original was cracked and went through the outdrive to inspect and replace the seals in the water pickup tube and so on... upon inspection I found a lot of melted plastic which I'm guessing were the flaps you were referring to (#22)?
Anyhow, just fired it up yesterday afternoon and ran it for a good 15-20 minutes with the ear muffs on and all seems to be functioning fine.... looks like 160-170 degrees with tap water running through it?
Thanks.
Thanks.
