First time for everything
Thread starter- Joined
- Jul 20, 2009
- 13
Good morning,
I have a question regarding the mounting of the carburetor and spacer to the intake manifold.
I am going to try to upload some pictures to help explain. I have a 1990 OMC 5.8L and the intake manifold has the 4 round hoels and then the oval shaped hole off to the side. (manifold 5 pic)
If i install the spacer and gasket with the "nipple" facing to the front of the engine it leaves a gap at the rear of the carb and spacer and causes a leak. (manifold 1 pic) (manifold 3 pic)
I see the spacer has a block off built in but the "nipple would face to the rear of the engine. (Manifold 4 pic)
OK question, which way do I install the spacer, facing front or rear and to I block off the oval shaped hole on the intake and just have a tube attached to the "nipple" running to the PCV valve on the valve cover?
Thank you!!!!
Thank you!!!!
