Tnstratofam
Thread starter- Joined
- Aug 18, 2013
- 2,679
Ok sports fans here goes. We own a 1988 Stratos 2000XLS with an OMC 350 with a king cobra outdrive. This is our families first boat, I know I already here all the sighs from the OMC haters out there, live with what Ive got. Anyway we've had the boat out about 4 times this year with no problems until we ran it out of gas about a month ago. "Note to self fix fuel gauge." So we get her home refuel her and the next time out everything's going all fine and then she just bogs down and dies. I could restart the engine, but when I put her in gear she just stumbles and dies. The engine would rev ok in neutral but nothing in forward or reverse. Got towed in. get home check paper fuel filter in carb ( Rochester Quadrajet ) it looked nice and clean. changed water fuel seperator filter, it did not look great. Engine started fine on muffs in the driveway so we went back out. Again boat ran fine for 20 minutes or so and died. Same problem as before will start and rev fine in neutral, but dies in gear. The one thing I did notice was that as it was building up speed to plane out it seemed the carb or engine was struggling to get up to rpm. I have been reading some of the forums on here for quite a while and am new to iboats and boating in general so ahead of time I thank you all for any and all support you give all of us newbie boaters. I'm planning on draining the fuel tank and checking the lines to see if any of them are blocked or corroded. I will probably also pull the carb and clean it at the least. Where to go from there? Any help would be appreciated. Happy boating to all.
