older ski boat restoration.......and so it begins.
Woodonglass
SS, I see em Just Fine!!! I'm right there with you on the welding. I'm NOT a welder and the limited welding I've done was with a Lincoln Stick welder. I was able to Swirl on some welds that did the job and didn't know much when I did it. Not sure I could figure out how to use all the new fangled stuff. Looks like you've done some welding before too!!! Some nice swirls in that weld from what I remember about it and again that Ain't much!!!! The way I look at it is if the trailer stays together then the weld was a good one. Some Grinding and Paint will make it look good!
nurseman
NOW I can see them...weird. Welds look pretty good, but I'm not a welder either! Like Wood said, grind em smooth and paint em up!
proshadetree
Older welders had much better windings. Some newer are even made of aluminum which is not a great conductor. I personally love the old Lincoln tombstone .
Woodonglass
That's the one I learned on!! The Tombstone!!! Wish I woulda learned more.:blue:
