Hello,
After getting some great help on my boat resto I thought I would post this here and see if anyone can help! I have just got the boat off the trailer for painting so thought I would repair the trailer at the same time.
The trailer tows really nicely but the brakes don't work at all (as I found out coming up to some traffic lights!). I tow it with an Audi Allroad, which does the job fine but the trailer needs good braking. The problem is with the coupler I think as I can depress it by hand and it doesn't spring back so I am going to replace that whole unit. The suspension seems to be completely rusted solid so I was planning on changing all the units to replace them with new braked suspension units. But on closer inspection I have found that the current ones disappear straight inside the axle and aren't bolted onto it as I expected.
I'm not sure how they are attached as there are no bolts underneath holding them into the axle at all. I presume they must go all the way through to the other side? Does this mean that the whole axle has to be changed? I have some DIY skills and can give most things a go if I have some instructions but have no welding knowledge/experience. Would this be a job better passed over to a professional?
The chassis is galvanised and in good condition. Some of the brackets/fixings are a bit rusty so I'll clean them up. Was thinking I might paint the whole thing so it looks as good as I am hoping the boat will. I've removed the old bunks and am going to put new ones on and am planning on fitting it with submersible lights, which will hopefully be a lot better than just a lightboard and reflectors.
Thanks in advance for any help/suggestions.
