Old Screws
thord
I am replacing seals and gaskets on the lower unit. There have been several screws twist off at the head and I need to order new ones. My question is should I replace all the screws and where is the best place to buy them?
I have an 1960 Evinrude Lark 40 hp. Thanks.
F_R
Re: Old Screws
Which ones did you break, the ones that hold the rear cover? Those are part number 305745 and are listed as no longer available. The last price was $3.03 each.
I'd try www.mcmaster.com Search for fillister head screws. They certainly will be a lot less expensive.
R.Johnson
Re: Old Screws
What screws' are you needing? If on the lower skeg, Allan head, stainless steel cap screws', 1/4- 20 would be the easiest to find.
thord
Re: Old Screws
One of the impeller housing screws, a lower gear case screw, several exhaust cover screws. i have a parts manual with part numbers, and marineengine.com has them. i did not know whether to replace all the screws or just the broken ones.
thanks
R.Johnson
Re: Old Screws
That would depend on their condition. Is there enough of the empellor housing screw left to get a hold of
kenmyfam
Re: Old Screws
Go to an actual industrial fastener place. You will find everything you need at a fraction of the price and equal or better quality.
rusirius
Re: Old Screws
I believe most of the screws you're talking about should be standard 1/4-20... You can pick them up just about anywhere really... Any hardware store for that matter... If you can't get the old ones out, just drill 'em and insert heli-coils... Also, just make sure the "hardness" is the same (indicated by the "marks" (or lack thereof) on the head)
thord
Re: Old Screws
yes, i have been soaking it in pb blaster and tapping it with a hammer. i will try to use a vice grip wrench to grab and twist it out this week.
is there anything else i should do for this one?
