MaleficentArmy
Thread starter- Joined
- May 10, 2012
- 22
i have an old martin 20 2.3hp outboard motor from the late 40's and its a 100% complete motor all original with working wobble pump and poppet valves even. it has compression, it has strong spark, and its getting fuel cuz the spark plugs are getting wet when i try pulling it over too much. ive cleaned the carb and tried adjusting just about everything, and the timing seems right and everything is functioning properly. im just baffled as it wont start! ive spent days on this trying to figure it out. its a 2 stroke, and i did replace most of the gaskets. the only thing i couldnt get to was inside the crankcase. 6 bolts hold it together and ony 5 come out. the last one is stuck because the previous owner used rock hard copper head gasket sealer for the 2 halve of the crankcase. i love this little motor and really wanna see it run, i just have no idea what to do. help please???
