Old gas.... what to do?
heyttown
Ok folks 3 yrs ago I got started tearing apart a car motor for a rebuild....Long story short,got laid off,and the cash just wsnt there anymore to work on the car so it sat..... worse part is car has amost a full tank, im guessing at least 18 gallons....What are my options.18 gallons would be tough to syphon(SP?) out and dispose of since the large quanity....Unfortunatly no fuel stabelizer was ever put in the tank as it was originally going to be a short term thing...Anything I can add (miracle in a bottle) to use any of this gas? I just had the Holley carb rebuilt as it was all gummed up, so I would hate to run bad gas through it right from the get go...<br />Any and all ideas appreciated.
JB
Re: Old gas.... what to do?
Mix it with new gas... about one part to 4 parts new stuff, and burn it in any CARBURETED 4 stroke implement or vehicle.<br /><br />Good luck. :)
Boomyal
Heyttown, get a syphon pump. Take two 5 gallon cans. Draw out 10 gallons and pour one of the cans into one of your other vehicles that has at least 15 gallons of gas in it. Go fill up the empty with fresh gas and pour it into your project car. Drive your project car down and top off the tank with fresh gas.<br /><br />With the remaining can of old gas, just pour it into your other car when the tank becomes a 1/4 empty. I'll try to find a pump link on iboats.<br /><br />Every boat should have one of these on board.<br /><br /> http://www.iboats.com/mall/index.cg...y=pump&**********=543434577&*******=608561217
heyttown
Thanks guys, anybody ever use the hand pump linked by Boomyal....I had an cheap hand pump that only lasted about 1 yr if that....Does that work good and last long...
Boomyal
Originally posted by heyttown:<br /> Thanks guys, anybody ever use the hand pump linked by Boomyal....I had an cheap hand pump that only lasted about 1 yr if that....Does that work good and last long...
I've had one in my boat for about 9-10 years. Never used it until last summer when I lent it to a neighbor to pump the gas out of his boat. It worked fine. Hold the pump as close to the ground level as you can. It will both pump and siphon.
ndemge
had same problem with my old van...<br /><br />I disconnected the fuel line that goes to the fuel pump, put a can under it...<br /><br />Air hose in hand, put a shop towel around gas tank filler, gave it some pressure and this started the siphon.<br /><br />probably took me an hour to get all the old gas out.<br /><br /><br />....check with local recycling places, a lot of cities will have a place you can take it to dispose of.
SS MAYFLOAT
I have heard that it makes for a good weed killer. However I think it is surpose to be againt the law. So if you are a law abiding citizen, don't use it for that. ;)
KaGee
....check with local recycling places, a lot of cities will have a place you can take it to dispose of.<br />
If you check you will find there are few places for individuals to recycle old gas. <br /><br />My buddy runs a shop and repairing fuel tanks is their specialty. It costs him over $3.00 a gallon to recycle. And then only in approved *sealed* 50 galon drums. Their advice is the same JB gave... burn it up! They only recycle extremely contaminated fuel.
craze1cars
I like the "gradually burn it in a functional motor by diluting it with good stuff" plan, and have used it many times with no problems (in fuel injected cars, too), but use a little caution. <br /><br />I once drained less than one gallon of 2 year old gas from a lawn tractor and dumped it into my company car (03 Chevy Malibu) that had at least 12 gallons of fresh in it. About 1 mile down the road, it started sputtering and eventually died. Best I can tell it had water in the gas. After towing it back home I forced the car to start and run on ether (YIKES! it's jus a company car, they're tough!) for about 5 minutes and eventually the crap pulled through and everything seemed OK. Motor had an occasional "cough" for several tankfulls after the fact (I think it was still finding some small pockets of water as I hit bumps & turns), but no lasting problems.<br /><br />Hopefully, since you have a FULL tank of bad gas, there was no room for condensation to build up and you shouldn't have any water in it. But you might be smart to dump a bottle of iso into the car you burn it with to help dry any water that's in there.
JustMrWill
Master Chief Petty Officer
Ok....buy (3) 6 gal gas cans. Siphon old gas into these. Rent a car (budget usually has nice cheap rates...only gonna need it 1 day...make sure it is mid-size or better...remember you need a 18 gal tank). Siphon gas from rental into your car...and pour old gas into rental...return and complain about how lousey it ran.<br /><br /> :) <br /><br />-JustMrWill
kenimpzoom
Originally posted by JustMrWill:<br /> Ok....buy (3) 6 gal gas cans. Siphon old gas into these. Rent a car (budget usually has nice cheap rates...only gonna need it 1 day...make sure it is mid-size or better...remember you need a 18 gal tank). Siphon gas from rental into your car...and pour old gas into rental...return and complain about how lousey it ran.<br /><br /> :) <br /><br />-JustMrWill
Youre evil...evil I say!!!!!!<br /><br /> :D <br /><br />Ken
dolluper
Originally posted by JustMrWill:<br /> Ok....buy (3) 6 gal gas cans. Siphon old gas into these. Rent a car (budget usually has nice cheap rates...only gonna need it 1 day...make sure it is mid-size or better...remember you need a 18 gal tank). Siphon gas from rental into your car...and pour old gas into rental...return and complain about how lousey it ran.<br /><br /> :) At the prices of gas you might back even after paying for the rental and you have fresh gas as long as you don't get the car the above just returned :eek: :D <br /><br />-JustMrWill
Originally posted by JustMrWill:<br /> Ok....buy (3) 6 gal gas cans. Siphon old gas into these. Rent a car (budget usually has nice cheap rates...only gonna need it 1 day...make sure it is mid-size or better...remember you need a 18 gal tank). Siphon gas from rental into your car...and pour old gas into rental...return and complain about how lousey it ran.<br /><br /> :) <br /><br /><br />-JustMrWill
Ayuh,..................<br /><br />This IS the Best Plan................I Love It........ ;)
ndemge
Yeah.. Mr Will's got it.<br /><br /><br />.... my brother drained his boat after sitting for a year... had 10 gallons of 2 cycle.<br /><br />poored it on my brush pile, ran a 40' of sticky match out, gave me a full minute of run away time.... WOOOOSH .. the mushroom cloud was awsome!
Originally posted by nd3mge:<br /> Yeah.. Mr Will's got it.<br /><br /><br />.... my brother drained his boat after sitting for a year... had 10 gallons of 2 cycle.<br /><br />poored it on my brush pile, ran a 40' of sticky match out, gave me a full minute of run away time.... WOOOOSH .. the mushroom cloud was awsome!
LOL<br />Check stupid human tricks.. has something to do with leaves... :D :D
piglett
I was just reading these and had no intention of posting, but......<br /><br />I like the mushroom cloud one.<br /><br />I've almost blown myself away in the back yard trying to light the fire on more than one occasion.<br /><br />My wife gets really pissed when she hears little explosions coming from the yard.<br /><br />HEHEHEHEHEH
ndemge
...remote detonation is key when playing with gas :)
mattttt25
just don't get the great idea of using a shopvac to siphon the gas quicker.
one more cast
I had a couple gallons of old old 50:1 mix and My daughter had a flea infested couch that someone gave her. I just saturated the couch with the 2 gallons of old gas and lit it. The fleas were gone, the gas was gone, and the couch was gone. I wouldn't recommend this because it made some awful looking black smoke and that cant be a good thing.
Vlad D Impeller
Originally posted by One More Cast:<br /> I had a couple gallons of old old 50:1 mix and My daughter had a flea infested couch that someone gave her. I just saturated the couch with the 2 gallons of old gas and lit it. The fleas were gone, the gas was gone, and the couch was gone. I wouldn't recommend this because it made some awful looking black smoke and that cant be a good thing.
In the process, you also temporarily got rid of most of the mosquitoes in your neighbourhood :D
