Old 6 hp wizard made by chrysler
Chrisham
Coc6506a86 I think this is a 1965 6 hp made by chrysler.What oil ratio should I run and what plugs
Chrisham
I put the gas to this thing and it cracked 2nd pull and is pumping good.Running 24/1 still not sure if this is correct .It's a wizard chrysler built coc6506a86
Western Auto Wizard oil ratio has been covered on iboats prior
Nordin
As it is a 1967-68 it suppose to have needle bearings in the crank shaft and in the connecting rods (the Chryslers does).
You should be able to run it with less oil than 24:1.
