old 10 HP Johnson... need parts
RandyJ
Master Chief Petty Officer
I've inherited an old 10 hp... not sure of year... model number is FDE10??. Need head gasket, possibly rings, could use a carb kit. Year & any parts source appreciated. Would like to get rid of the two line set up if anyone has a fuel pump I can adapt to this engine.<br />Thanks,<br />RandyJ
JB
Re: old 10 HP Johnson... need parts
Howdy Randy.<br /><br />Your FDE-10 is a 1956 15hp.<br /><br />Your JohnnyRude dealer probably has the parts you need, or can get them.<br /><br />If you have no luck there, try www.twincityoutboards.com<br /><br />Good luck. :)
Chinewalker
Hi Randy,<br /> Your old 15 is one of the best motors OMC ever built. Adding a fuel pump is fairly straightforward - just need an intake port cover with the fuel pump boss cast in from a 1960-early 1970s 18/20/25hp Johnrude. Plug off the pressure line feed, add any block mounted OMC fuel pump and you're off to single line land.<br /> If compression is good (after you've found a head gasket) I'd go ahead and run some de-carbon agent through it (like Sea Foam, OMC Engine Tuner, etc.) and run it! As long as the motor doesn't make any obscene noises or sound like a coffee grinder, it should be good to go. A new water pump impeller and lower unit seal kit will help keep her going. Manuals are available here and on several other sites on the net.<br /> Have fun!<br />- Scott
