ok im close to getting this motor going
marzoid
so an update
My motor wouldnt stay running on idle. So I cleaned the carbs to potentially fix the problem.
In the process I must have disrupted something else. Or it just happened at the same.
Anyways my motor wouldnt start up and run after that. (Fly wheel would turn...it would sound likes its trying to start)
I found that the top 2 sparks would not spark very well...the bottom 2 were fine
I replaced the coils....I still have the same problem
It has spark on the top 2 now but its weak nowhere as good as the bottom 2
Could this be a bad switchbox?
What else could it be?
and would this stop my motor from starting....from what ive read it should still start even if i do have very little spark
thanks alot
oh btw its 1985 75hp 4 cylinder 2 stroke
(ive taken apart the carbs and their fine...it is getting fuel)
when i try to start it i will get some smoke...and it sounds like its really close to starting...ive played with the idle adjustment and still get nothing ive also sprayed gas into the carbs.
Gibbles
Re: ok im close to getting this motor going
If you have a volt meter try and check the ohms through the wiring harness plug.
Very common to have these rot out and do just what your describing
marzoid
those are the wires that go from the switch box to the coils?>
CharlieB
A hot blue 7/16 inch arc is needed on all cyls.
Failing that, you can download the FREE Ignition Troubleshooting Guide from the Sopport pages of CDIElectronics
Their easy to follow step-by-step guide directs you how to test each component of the ignition system to identify the defective item.
You will need a DVA meter or a DVA adaptor for any volt/ohm meter. An adaptor can be built quite easily and cheaply following the directions posted here
http://forums.iboats.com/showthread.php?t=374544
Remember, there is NO RETURN on electrical parts, test twice to be sure before ordering any parts.
marzoid
Thanks Gibbles you got it!!! thanks so much
I ended up switching the two harness wires and my boat started right up
thanks so much
im going to replace both harness wires
Gibbles
np, glad it worked for you :)
