oil seal
frank27
which is the top and which is the bottom on one side i can see the small spring around the rubber
kbait
Re: oil seal
Which seal are you referring to? Normally, gearcase seals have the spring toward the lube.
sutor623
Re: oil seal
Yes, yes. I don't remember seeing an oil seal where I could see the spring on the outside....
sutor623
Re: oil seal
Oh sorry, let me clarify. If it is the waterpump base, the spring points up. If it is the waterpump housing, the spring faces downward.
kbait
Re: oil seal
Just don't drive the seal in from the spring-side, and you're good to go.
