glennhoward
Thread starter- Joined
- May 6, 2009
- 19
my 150 txry 2 stroke year 2000 main oil tank is not transferring oil to the
engine sub-tank. i have replaced the engine tank mounted float switch/harness,
insured the trim indicator is working correctly and down, checked the two fuses in the key switch wiring harness, replaced the main oil tank system completely checking the harness for conductivity, cleaned every connector with contact cleaner all with no success. engine runs great until the engine mounted oil tank level reaches lower level then the engine will idle only until i flip and hold the emergency switch located near the cdi which activates main oil tank pump oil to the engine sub-tank. i don't know what else to try. could my cdi be kuput (hope not, this part costs over $1,000) HELP. glenn
