Oil Leaking
BT
I Have 2 200 Hpdi Yamahas That Leak Oil When They Are Tilted The Year Of The Motors Are 2000 . It Looks Like It Is Dripping From The Plastic Container On The Engine . Any Help In Repairing Would Be Appreciated Thanks .bt
choice77
Re: Oil Leaking
try clamping the oil level sensor w/ a tie strap or better yet use the curved- head tie straps used on outboard fuel systems. install the clamp over top of the small arrow aligning the sensor to the reservoir. you can also verify that your airbox cover is tightly attached w/ all screws and that the gaskets/rubber seals are in place and in good shape.
JUSTINTIME
Re: Oil Leaking
yep it will be the engine mounted tank
always keep motor trimmed down when storing
