Re: Oil leaking from lower unit
Thank you. At first it was black with gas mixed in. Changed lower gear lube, now it is amber with gas mixed in. Onlty happens after we put rabit ears on and test motor. Had someone tell me we needed carb rebuilt. Could that be the problem with the leak. If yes, is rebuilding carb an easy job? Engine has 2 carbs. Is it a do it your self kind of job?:redface:
