Oil leaking from lower unit
shrimpfinder
I have a 1994 Mercury 40hp I have an oil leak under the propeller. The oil is not milky. What could be the reason?:confused:
Faztbullet
Re: Oil leaking from lower unit
If it is black oil take some on finger and smell it, if it smells like fuel you may have a carb thats leaking an running down thru exhaust. It dissolves carbon in exhaust tube and looks like black oil.
shrimpfinder
Thank you. At first it was black with gas mixed in. Changed lower gear lube, now it is amber with gas mixed in. Onlty happens after we put rabit ears on and test motor. Had someone tell me we needed carb rebuilt. Could that be the problem with the leak. If yes, is rebuilding carb an easy job? Engine has 2 carbs. Is it a do it your self kind of job?:redface:
Faztbullet
It changing colors seem to indicate a lower unit leak. You can test the seals with a vacuum/pressure tester to find bad one but just as easy to install a complete seal kit and be done with it. Carbs are pretty easy to repair ,nut on lower carb is a little difficult to remove under starter bracket but if you bend a 7/16 wrench about 40 degrees it makes it a lot easier.....Also check your PM
