Oil leak
craig giles
I just notice a oil leak where it looks like a vent hole but water come out when I crank my motor with a water muff. In the picture you will see that hole . My question does anyone know if there is a seal in this area , oil will come out after I turn the motor off , the oil is black . Does this sound like a easy fix. This is a 90 hp murcury outboard. I'm a new boat owner I hope I explained it right. Any suggestions . Thanks craig
Chris1956
Smell the oil. If it smells like gas or oil, it is likely residual fuel. If it stinks like eggs, it is gear oil and you likely have a leak.
