I recently purchased a 1992 Johnson 48SPL. It runs good but I have noticed that after I run it for a while with the muffs on and then let set for a few minutes that I have a little bit of dark colored oil leaking from around the prop and dripping on my driveway. Is this something to be concerned with, maybe a seal gone bad. I have attempted to remove the oil lube drain and vent screws to check the lube level and to see if the lube is water contaminated but they won't come loose with a regular screwdriver, may have to try a impact screwdriver. The oil that is slightly dripping is dark in color and not a milky color. Someone told me that the oil that is dripping may be just unburned oil dripping out of the exhaust, could this be my issue. I am new at this and have not owned many boats and motors. Thanking you in advance for any responses and assistance.
