Oil leak
Jaffi
I recently purchased a 1992 Johnson 48SPL. It runs good but I have noticed that after I run it for a while with the muffs on and then let set for a few minutes that I have a little bit of dark colored oil leaking from around the prop and dripping on my driveway. Is this something to be concerned with, maybe a seal gone bad. I have attempted to remove the oil lube drain and vent screws to check the lube level and to see if the lube is water contaminated but they won't come loose with a regular screwdriver, may have to try a impact screwdriver. The oil that is slightly dripping is dark in color and not a milky color. Someone told me that the oil that is dripping may be just unburned oil dripping out of the exhaust, could this be my issue. I am new at this and have not owned many boats and motors. Thanking you in advance for any responses and assistance.
Honorary Supreme Mariner
That " apparent leak " is nothing to worry about.----That is normal unburt fuel and oil from the exhaust.------Noticed after running on a hose !
Jaffi
Thank you racerone that is good to know. As I mentioned before it is not a lot of oil. Still having trouble getting the drain and vent screws out though to check and refill with new lube. Any suggestions as I don't want to mess anything up.
Will Bark
An impact screwdriver is a handy tool to use; just make sure you don't mess with Phillips head screw only fill and vent screws. good luck
Jaffi
Thank you Will Bark, and I was told several times to stay away from the phillips head screws,as that is a big no no, but thanks for the reminder. Still having trouble removing the vent and drain screws. Any suggestions, as I don't want to mess anything up as this is an older motor, in real good shape though.
Bosunsmate
1992, isnt old at all, thats still a juvenille.
Those stuck ones i find really do need an impact driver. I hit mine with a rubbet mallet, harder and harder until it finally goes.
Always start on the top one as if you get the bottom one undone but not the top you will have no idea when its filled back up correctly
Itd be most likely worth your while changing the lube in there.
500ml of marine gear oil bottles normally fill most of the mid size motors 30-60hp.
If you do change it be sure to use a fluid pump and pump from the bottom up otherwise you will get airbubbles and a wrong oil level.
F_R
No Title
For those not in the know, a hand impact screwdriver has a cam inside that rotates the bit when you whack it on the end with a hammer. The hammer blow does double duty by keeping the bit in the groove as it rotates. It will get those screws loose in one or two whacks. Anybody that works on outboards will soon find out that it is an absolutely necessary tool. BTW, no need to be gentle with it, go ahead and hit it with a real hammer. OR..also realize that it actually is possible to twist off a frozen screw if you get violent enough.
Jaffi
Thanks hardwater fisherman, Bosunmate and F_R for the info and assistance. Took me awhile to get the screws out. My impact screwdriver would do the job, as it has a tapered tip and kept slipping out of the screw head groove. Had to use my son in laws Snap On Brand as it has a has a more straight and blocked type of tip. When draining the old lube out was happy to see that it was just dark black and not a milky color and that there were no chunks of metal stuck to the magnet tip on the drain screw, just a few slithers of metal or shavings if you will. Thanks again. I am learning a lot from you folks on this forum.
Bosunsmate
No worries, glad they came loose.
The other thing you should really do on any motor just obtained is to replace the impeller that pumps the water- unless you are ultra confident it has being done recently. The impellers need to be done every two years
