oil leak
barglow
My 50 hp 2002 mercury leaks mixture oil from reservoir thru bottom carburator onto floor of the cowel. What is responsible for shutting oil off while motor is off? Please help.
M
Maxz695
Guest
Re: oil leak
it,s normal for fuel to leak out of the carbs when it gets tilted up when trailering..But sre you sure it,s coming from the bottom of the carb or just dripping down on to the bottom of the carb? The gas escapes through the carb vent on top of the carbs (Both) then may be dripping down from there. The floats move when lifted allowing gas to escape through the Needle seat and out of the carb vent DO NOT PLUG THESE UP> It will affect you fuel flow
barglow
Re: oil leak
No this is a gravity leak & after a while will empy out whole reservoir.
