oil leak
icfish
I have a 97 force75 it is leaking black oil by the back of the prop and down the bottom fin<br />does anyone have any idea what this could be
force01
Re: oil leak
lexx<br /><br />properly maintained gear oil will not be black, but if your motor is not being serviced properly the oil will turn black.you either have a leaky seal in your gear case or this is unburned fuel \oil draining down the chamber, you would only expect to see this if your motor was not running well example on two cylinders.drian your gear case oil in a clean pan check for water, metal, shavings and color of oil,if you find the gear case to be the problem it will have to be resealed good luck bret
