philbullet
Thread starter- Joined
- Aug 14, 2014
- 241
I had removed lower unit on a gen. 2 to change water pump impeller and I notice some gear oil came out of upper part with drive shaft when removed.
Change water pump and put back together, changed all oil out of gear case to resivor.
Now I notice some drops of gear oil on ground.Seems to be coming from upper gear case where drive shaft goes into.Also the level in resivor tank dropped a little bit just sitting there.
Iam thinking I my have a bad seal now?
Any suggestions of how difficult this will be.
