Recently I discovered a leak in my lower unit. It appears it comes from the shift shaft as you can see in the image within the red circle http://imageshack.us/a/img4/5572/njqv.jpg When I push air through the oil fill hole the shift link goes a little bit upwards and air/oil is coming out. That isn't normal right?
I already managed to losen part 8 and 11 from this exploded view Mercury, Mercruiser, Force, etc. - GEARHOUSING ASSEMBLY - 40 H.P. but I can't seem to find a O-ring/oil seal. Is part 74 to 77 also parts of the shift shaft? I can't figure it out how to fix this problem. Is there maybe a youtube video about this problem?
And another little question: which gasket(o-rings,gaskets,seals) kit I should buy for a Mariner 40hp (40 EO - 6E9 S 150087) for my lower unit?
