Oil leak at front crank?
SSTKO81
Looks like I've got a nasty oil leak from just behind the harmonic balancer. I'm guessing this is the front crank seal and I'll need to pull the balancer but I'm having trouble figuring out the part number for this seal. Anything I need to be aware of when doing this?
kmarine
Did you say what kind of engine you are referring to
SSTKO81
Sorry. I guess that would help... it's an '81 mercruiser 140.
Bt Doctur
[h=1]18-1213 - SEAL, 26-97335, 3853341[/h] Replaces OEM #3853341. 18-1213 Seal Timing Cover 26-79223 26-59341 97335
SSTKO81
Haven't pulled the balancer yet. I'll go ahead and pick up the seal, then find out what I'm working with on the cover. -sounds like it's got the potential to be a mess
worse case, you pull the motor to replace the front cover and oil pan due to rust-thru issues
joetheis
Here is food for thought............
I've been a Chrysler tech for, well a few more decades than I care to say!
The seal could be just hard from heat/ old age.
BEFORE you pull the harmonic balancer, take 2 pry bars, or 2 big screw drivers, push IN on the balancer then pull out, (crank shaft end play).
there is a thrust bearing in the middle of the crank that limits the forward/backward movement.
In 40 plus years I've had 2 cranks that had too much movement, but..........
Pull the balancer, look where the seal rides, should be NO grooves.
If there is.........
You can buy a seal kit, it has a sleeve that slides over the balancer and a different seal to get a smooth groove free surface for the seal to ride on. (It's a GM engine, go to Napa or?? and ask for the seal kit).
Make sure you grease the lip of the seal when you install it, (have seem more than a few installed dry, a few miles later leaking again).
Front seal should take you hour er 2 depending on the tools, (a good puller), clearance you have.
Not a hard nor messy job.
Joe
as always take any advice I give with a can of beer er 2!
SSTKO81
Well the timing cover is in good shape; no rust, but the fiber cam gear is missing the points on nearly every tooth. -not to the point where it looks like it would jump time or ever has, but what would cause this? And I'm concerned because I can't see how I would go about removing this gear for replacement. Insight?
SSTKO81
BACK TO TOP::::
Does anyone have any input on how to remove the cam gear for replacement? Or is it even worth in considering the gears are obviously still tight and not slipping?
