Re: Oil injector probelm
How do you know it's not pumping oil? How did you bleed the system?
You can verify the pump by hooking motor to an aux tank of 50:1, disconnect clear hose from fuel pump, disconnect link rod and turn oil regulator full wide open. Then start the engine on muffs or in water. Does any oil pump out? My book says you should get 18.7 cc idling for 15 minutes.
